[SOLVED]820-00426 No Backlight
JohnB8812
Got this one in with no backlight (note said sent out for backlight repair before but not fixed). Inspected board no liquid damage and no sign of previous rework. Backlight output was 0 volts and in diode mode on pin one of the LCD connector I got 0.169-0.18. Replaced LCD connector but no change.
Fuse has 12.6 volts on both side.
Machine boots into an OS and has image, BUT no backlight.
Would LED driver be the next logical conclusion?
Thank you for the help
G.Beard
You've tried another screen cable and inspected the iPEX connector on the screen side first of course?
Made sure no beep from pin 1 to ground with cable plugged and unplugged?
Tested with another screen of the same model (numbers under the clutch cover / WiFi thing)
Beeped out pin 1 to ceramic caps to make sure the trace is good?
Someone will likely tell you how to do fault find properly but I don't bother to figure out issues when it's just as quick to slap another backlight circuit on there (the most likely failed parts of course and after I have tested everything other than the board).
If it does not work, then start using brain and looking into PWM and feedback traces, etc.
LCD needs to talk to the backlight driver on the board. First is to try with a known good LCD assembly for the correct year of course.
JohnB8812
Ok will do grabbed a test 2015 from a friend today since we did not have one. Wanted to test before LCD connector replacement but tried it on the off chance it was the connector. Will test with known good next time I see the board
JohnB8812
Tried known good LCD and success! Backlight works! (Gonna convince friend to let me keep the test screen lol) Mark as solved!
JohnB8812
It's a customer's that was mailed in, and I don't have any spare LCD cables, but I did tell them to do that because could be that simple.
