[SOLVED]820-00875 - Tripping keyboard backlight
smiba
Hey everyone. I have a Macbook Pro Mid 2016, 13" here (non-touchbar) with a tripping keyboard backlight after top case replacement.
The top case was replaced after water damaged the keyboard and all the components such as the battery and trackpad were safely moved over to the new top case.
Apple diagnostics pass and the system doesn't seem to have any issues, expect that the keyboard backlight does not work properly
I've made a video here: https://www.youtube.com/watch?v=KJyRKo23h3w
The keyboard does stay at the same fixed brightness but the individual keys go on and off depending on the keyboard brightness thats set at the system. If you change the keyboard brightness some keys will turn off while others turn on. The keys that turn on/off are always the same for each brightness setting, meaning that for example when you're at "full brightness" you will always be missing the same keys.
Is this a motherboard problem or a keyboard problem? I hope the first because I really don't want to go through the process of getting everything out of the top case again :(
Cheers
smiba
Well that was a quick one, resolved it by reconnecting J4801 as for some reason apple decided to let the trackpad control the keyboard backlight (lmao?)
