Alan.L
[SOLVED]820-2330 Macbook Pro 15" Late 2008 - turn on when long press on button button.
Hello and Merry Christmas to everyone
when shorting the power pads, the fan will spin for 1 sec then stop. But when i shorting the power pads for 5sec+ then it can turn on fine.
ASD EFI and OS passed all tests. i replaced the c7771 even wasn't at fault.
board is not liquid damage. cant see any corrosion under microscope,
R5710 is fine
when i plug the keyboard flex back in, i am not able to perform SMC reset (Magsafe + Left Shift + Control + Option + Power )
SMC_ONOFF_L measured at 3.4v and drop low to 0.3v when i press power.
charging the battery is fine. does same problem when i i use battery power only.
My 85w charger is REAL and i also have tried another 85w charger.
#Edit, can a mod fix my thread title.
cheers!
Alan
R5710 is fine
cheers!
Alan
