BCConnection
820-2530 light water damage around LVDS
Replaced LVDS and computer works fine when plugged in.
If you unplug the charger the computer shuts off right away.
Charger plugged in Green and turns Orange
OSX sees the battery, battery cycles, battery status, and battery percentage
Battery Gate Q7050 is working and shows batt voltage on both sides and gate pin is 5v
R7008 shows same voltage on either side
F7000 shows same voltage on either side.
74% batt voltage is 11.76V
BIL does not show anything when pressed or charger plugged in. Lid switch does work.
Different battery has same results and BIL connector disconnected and it does the same.
