[SOLVED]820-2849 no bluetooth
arnonabuurs
Hi guys, got this 17 inch 2849 in with no BT, wifi working fine. Replace the AIrport card and same issue, also tried a clean OS. Never fixed this issue before other then just swapping the card where to start?
aprendiz
Moderator
Bluetooth is just an USB device, check L3404, maybe it is open also check voltage on both pins ftom L3406....
