[SOLVED]820 2849 no light no mag safe when battery is connected
EJS
820 2849 no light no mag safe when battery is connected, as soon as battery is disconnected green light returns. Machine will boot, but only if I plug the battery after magsafe is plugged in. I have 3.42v on PP3V42_G3H...
3V42 present when battery connected? PPBUS with and without battery? ACOK from U7000 with and without batter?
EJS
3v42 is present when battery is connected PPBUS 7.38v with batt, and jumps like hell between about 3-6v with out batt. 0v with and without batt on ACOK.
aprendiz
Moderator
Check resistance between pin 17/18 and 27/28, also voltage on pin 2 from U7000.......
Do not use comments because we cant see when you post, use replay....
Some of these 2849 are a bit weird without battery is my experience. The important thing is that you are using an ORIGINAL Apple 85W charger, no 60W and no Chinese garbage!
EJS
Update, I was measuring on the wrong chip yesterday. U7000 ACOK has 2.32v without batt, and 3.19v with batt.
I have 3.88v on pin 2, 3.4ohms between pins 17/18, and 21.4 ohms between pins 27/28.
EJS
Pin 3 on d7005 I get 16.77v, pin 1 of r7003 16.77v, pin 2 of r7003 3.8v. I pulled r7003 seemed like it was reading a little low, replaced, same storey.
There is a 13V voltage drop over R7003. If R7003 measures about 20Ohm then it is either U7000 or C7005 pulling it down. My bet is a dead U7000.
