[SOLVED]820-2850 Only Posts With 2 GBs of RAM
I have a Crest 2.5 Gallon without heat. Using the 103 mL of Branson EC per gallon of distilled H20. I was low on 99.9% IPA when I did the post cleaning alcohol bath before going into the toaster to dry I am worried I didn't get all the water off the board even with 30 mins at 200 F.
We can mark this guy resolved! I put it through the cleaning process one more time and things are all good, probably crap that didn't get fully cleaned the first time.
Don't clean boards that don't need cleaning. C9560 can be replaced with a simple soldering iron. No need to remove RAM or heat sink or anything. Keep it simple.
