[SOLVED]820-2915 - Does not detect battery in OS, not charging or booting from battery
Status
Not open for further replies.
smiba
Hi there,
Customer came in with a 820-2915 motherboard that did not power on, replaced U7000 because bad voltages out and it booted again without issues.
The device has no signs of water damage or bad prior repairs.
The system does not detect a battery, It will not boot off one but if you pull the charger the device will not power off and keep on running from the battery (Until the OS finishes going in suspend). Once in suspend the system dies again while only connected to the battery
Pretty sure this is an issue with the SMBUS_SMC_BSA_SDA / SCL lines, but they seem to be doing ok-ish. I've seen 3.3V on SDA and pretty sure I've seen 3.3V on SCL as well.
I2C pull-up resistors are not closed
I thought I might have messed up the soldering so I swiped my iron another time on all the pins and ensured a proper connection. After that didn't work I replaced U7000 with another new chip from my reel but the same issue stays.
Where to look? There aren't many components connected to SMBUS_SMC_BSA and I'm starting to suspect the SMC. But all other sensors come back properly so I don't know.
Thanks in advance!
smiba
3 different batteries tried so far, BIL has been unplugged.
It just sounds so unlikely for the SMC to just fail on just one I2C line with no other issues with the system at all. Replacing the SMC has been a pain in the ass before so I always try to keep it as a last solution
roy.ruan
Pulled off the battery indicator. otherwise 99% is the SMC. I've seen a lot, when u7000 got a burnt hole, the charging function would be fucked and SMC needs to replaced..
smiba
I wanted to let everyone know that replacing the SMC fixed the issue, reballing indeed was quite easy and went right the first time.
ASD comes back with passed
Thanks again!
Status
