[SOLVED]820-2915 fan problem
Dozer
hi, i just work on that board.
it came in with gpu problem. after replacing it works everything fine.
now after 3 days i get it back to have a look.
after some minutes the fan begins randomly to run full for a second or half a second. then again noarmaly.
i run now asd only sensor check about 1 hour but not failing, nut i hear the fan problem is there.
i gave the smc a refloow but still the same.
is it a good idea to reball the smc ?
Dozer
i run the asd fan test and it failed in "unable to stabilize between min and max ....
replace the fan was resolving the problem :)
so easy sometimes ...
