[SOLVED]820-2915 ppvcore_s0_cpu
Status
Not open for further replies.
G.Beard
Hi.
No visible liquid damage at all. Was told liquid but the board is clean (other than skin flakes, carpet hair and bogies).
No power on.
About 5ohms on PPVCORE_S0_CPU
No working board for reference but I would say 5ohms is too low?.
G.Beard
5 ohm is fine. The usual PPBUS, 3V3_S5? You using a REAL 85W charger? Battery charging?
Yes real Apple 85W charger.
Battery... OUCH! fuck me I just picked up the board, found short on U7300 TPS51916 IC itself is burning.
Will try sort that out and get back to you.
G.Beard
OK, CPU burning my finger now so I'll test board.
3 beeps. I'll check the rest of the circuit.
G.Beard
Still beeping x3.
1.56V coming from L7330. ALL_SYS_PWRGOD is 3V3... OK I'm lost.
Go back to the start and test power rails?
What should I be testing here please?
G.Beard
I does chime.
First thing I tried was PRAM reset.
Not getting any signal for LCD_PWR_EN.
Nothing on PPVOUT_S0_LCDBKLT
Nothing on (scope) BKLT_PWM.
No output to external monitor.
No PM_ALL_GPU_PGOOD
U9800 shorted to ground, R8911 in the Mohms range
Status
