13.2V is not good. You sure about that? Should not be higher than 12.6V. But it should power on regardless, the usual PP3V3_S5? PPVRTC? Inspect for pre-fucked damage.
no orange light. PPVRTC = 3.3V, PP3V3_S5 = 3.3V ..the beginning i change u7000 and the machine start with battery but after that don't start anymore.. SMC bypass?
I can explain.. I was not sure that the U7000 chip was good. I paid 15 euros for 2 u7000 to make sure that what I was getting this good. I just had the bad luck not to soldering well.. I have now soldered the component well and now I can see PPBUS_G3H 12.3V .. now i know the problem is the SMC!
Are you sure the issue is the SMC? Because you're getting a green light so the SMC is atleast doing something.
You can't really properly conclude if the SMC is working based on the PPBUS_G3H voltage since your measurements haven't been the most accurate so far. Making it unsure if we're just looking at a lower PPBUS voltage or a inaccurate reading. (Are your batteries in your multimeter in need of a replacement?)
You can try to reflow it I guess, though.
What are the voltages of: PP3V3_S5, PP5V_S5, PP3V3_S4 now?
