[SOLVED]820-2936 MBP 13" 2011 - HIGH FAN - ASD: ERROR SMC IO FAILED
Status
Not open for further replies.
Alan.L
the board was liquid damage. i fixed backlight area..
someone has work on this board before.
things seem to be working but fan runs high, can run osx etc...
do i have a bad smc?
ASD give me:
Sensor = Temp (TC0D) -- CPU 0 Die analog (test1) - sensor reads within Operateing range...
check to ensure that sensor....
ERROR - SMC IO FAILED
Test Failed
Sensor = Temp (TC0P) -- CPU Proximity (test1) - sensor reads within Operateing range...
Test Failed
Sensor = Temp (TM0P) -- Battery Charger Proximity (test1) - sensor reads within Operateing range...
Test Failed
Alan.L
checking sensors on page 51 now...
U5510 looks good and all the surrounding resistors.
U5510
PP3V3_S0_CPUTHMSNS_R - pin 1 = 3.249v
SMBUS_SMC_B_S0_SDA - pin9 = 3.292v
SMBUS_SMC_B_S0_SCL - pin10 = 3.292v
Alan.L
found corrosion on U5410
replaced and didnt fix the adove problems.
any idea?
Alan.L
Q5520's voltages is constantly jumping:
pin1 = 0.959v-1.111v
pin2 = 0.530v-0.653v
pin3 = 0.937v-1.123v
Alan.L
R5260 = 4.2kohm - good
R5261 = 4.2kohm - good
diode mode
SMBUS_SMC_B_S0_SDA = 0.539
SMBUS_SMC_B_S0_SCL = 0.492
Alan.L
removed R5222/23
SMBUS_SMC_B_S0_SDA = 0.746
SMBUS_SMC_B_S0_SCL = 0.537
yep still different.
removed U5510
SMBUS_SMC_B_S0_SDA = 1.639
SMBUS_SMC_B_S0_SCL = 0.513
bad smc?
Status
