[SOLVED]820-3023 fan spin, S0 present, no boot
Joesipaq
Hello all,
So I have a MBA 2011 A1369 (EMC 2469) that has no "deadly" signs of water damage. (fly piss on a cap - cap tested fine, cleaned well)
There is no chime or beeps, but most all S0 power lines come on. ALL_SYS_PWR_GOOD is high,fan spins, green light, then amber.
The only voltage i notice missing is PPVCORE_S0_AXG_R. There is no voltage on pin 13 U7400.
Where would you go next?
Joesipaq
R7402 @ 91.3k
Pin 1. CORRECTION 3.31V
Ping 2. 0.3v but after probing pin 1, jumps to 7.74v (only when fingers are resting on probes - so with high resistance from pin 1 to ground, pin 2 gets 7.74v for a few seconds.)
Vcore present on L7510? If yes then all you can try is another BIOS and possibly hidden corrosion somewhere. These board are however infamous for RAM issues which is not worth bothering with.
Joesipaq
1.17v present on L7540.
That is a little low though is it not? I haven't messed around much with vcore so I'm not sure what its normal range is.
Thanks! Ill probably get another bios ready to try out too in the mean time
Joesipaq
as an fyi, the corrosion that i didn't think was important was on cap C1696 and apparently C162E. the one right below and closer to the ram. But they are now reading 1.05V.
Vcore is present so all power should be fine. Try another BIOS to be sure. After that it can be anything from crap under SMC to bad RAM/CPU/anything.
