[SOLVED]820-3024 EFi Padlock
Alan.L
No Title
is this right, do i just turn them into Zero "FF" ?
Alan.L
thanks gcain, i also found 3 more $SVS instances. so total of 4 all together. i replace them with zero?
gcain
No, just that one instance.
Should 321bytes from start to end.
I just copy 321bytes from somewhere then click 'Insert Mode' then paste it over the top.
Takes two seconds.
Alan.L
i dont have that copy bytes option in the hex editor.
anyway i've manually type FF which turns into ÿ
then i flashed and it is programming successful :)
i'll solder this chip back onto the board tomorrow.
thanks gcain
Alan.L
No Title
soldered, tested working :)
