I have a Macbook (820-3115) that came in "dead" and the customer states that a "whole bottle of water is in there."
It does not turn on, no chimes, no fan, nothing.
Battery LED meter on the side shows the battery at about 50%.
MagSafe gives me a green light but never changes to orange (always green).
Up until now the extent of my diagnostic skills have been limited to obvious things - in this case I would have thought there would be obvious water damage on the board.
There is no apparent water damage on the board. The only bit of green-rust/oxide build up that I could find was very small amount on C5856 cap near the key board light connector which really was not a problem at all.
I have read through the Beginners presentation power point and tried to check some things based on what I read there but the truth is, I don't yet know exactly what I am doing and I think I am just chasing a rabbit I will never catch without some guidance here.
I can tell you there is power in various places... initially I thought maybe a water spill caused some problems with the keyboard and power switch so I tried turning it on using the Power On pads (there is 3.45V on one pad) but it does not turn on.
I have the board out of the laptop and would appreciate any help I can get on where should I really start?
I should add... I do not have a working board to compare with.
