XooP
This board came in completely dead, no green light or anything. Made a visual inspection of the board, and oddly enough there where no sign og water damage at all.
The U7000 had a small crater on it so it got replaced. After replacing the U7000 I got green light and the fan started. Mounted the board back in the machine and found the machine running quite slow and not recognizing the battery. Tried with a well known battery, but still nothing. The BIL doesn't show anything when pressing the button either (tried two different ones as well).
The board does run on a charged battery but does not show up in OS. Ran ASD with noe errors.
Started measuring around the board:
- Current sensing resistors R7050-52 seems fine
- Q7055 Pin 5 is only 5-7V when battery is not connected
- R5280 and R5281 both measures good, and is receiving 3,42V
- The J6955 looks great
While sitting here writing I just realized that I haven't checked D6950 or R6950 yet. I will do this ASAP.
I do fear a bad SMC, but if anyone has any suggestion to other things I should check I would appreciate if you shared with me
