[SOLVED]820-3209 Missing PM_SLP_S4_L Headache..
Status
Not open for further replies.
MOberdick
I've been staring at this board for a long time now and for whatever reason cannot narrow down what's causing PM_SLP_S4_L to not enable. Received board with no obvious water damage or corrosion anywhere, it actually looks spotless. I do have PPBUS_G3H and a green light on the charger and what I have as a result of further testing so far is PP5V_S5 present, PP3V3_S5_PCH_PWRGD present, and PP3V3_SUS present. I know that the clock circuit is needed as well which I've got readings of 3.3v on pin 2 and 3.3v on pin VDD_RTC_OUT. I'm kinda stuck on where to go from here and was just seeking guidance to what to check next. Thanks in advance!
My misunderstanding..
R1801 3.3v pin 1.. 3.1v Pin 2.... 1M Resistance
R1802 3.3v pin 1... 1.2v pin 2... 20k Resistance
R1803 3.3v pin 1 and also 2... 20k Resistance
Could be corrosion under PCH, R1802 and R1800 measure a lower voltage than it should be (about 3V)...
Measure in diode mode red probe to ground on pin 2 from each resistor and report value...
I previously replaced R1802 because of the voltage difference but for whatever reason I didnt think to check for a partial short... It was C1802... Thanks Duke!!
Status
