Hello Everybody
Working on liquid damaged A1465 Late 2014. before come to me some ones clean board and replaced LCD connector and replaced bios , (I m not sure where liquid damaged)
Computer turns on and working but too slow and fan noise ;
When i checked by ASD
[12/31/13 16:25:49] Temperature (Th1H) -- Fin Stack (test #11) - Extended Sensor Flat Line Test
- Checks that the Sensor changes value i.e. not stuck, with longer time allowance for change (5 mins).
[16:25:49] ERROR - -13005 [The SMC can not read this sensor] -- TEST FAILED
[12/31/13 16:26:10] Fan Motor: Exhaust (test #4) - Turn On Automatically
- System turns on fan motor and verifies fan motor can reach minimum/maximum values
[16:26:53] ERROR -- 9 [Motor unable to stabilize between min and max limits] -- TEST FAILED
[12/31/13 16:26:53] Quick Fan motor Test (test #5) - Quick Fan motor Test
- System verifies that the fan motor is running to target speed
[16:27:12] ERROR -- 7 [Fan motor is spinning slower than it should] -- TEST FAILED
[12/31/13 16:27:12] Fan Motor: Exhaust (test #21) - Verify Max Speed Other Fans At Full, Min Speed All at Min
- Verify fan max speed with other fans at full speed, min speed with other fans at minimum speed
[16:27:57] ERROR -- 9 [Motor unable to stabilize between min and max limits] -- TEST FAILED
What was tested:
I/O board
I/O Flex cable
Fan
Trackpad and cable ( cable also damaged)
After some flux + heat SMC fan noise gone but machine working slow and same error at ASD, checked R5210 and SMC_SENSOR_ALERT_L no short to ground .
Is it looking like SMC problem or can i check any thing?
What was tested:
I/O board
I/O Flex cable
Fan
