[SOLVED]820-3435 internal ssd not working
Status
Not open for further replies.
iambehr
Hello,
Just wondering if anyone has experienced this issue this before. A known good solid state drive is not being recognized in the slot. The logic board otherwise works and has no signs of damage and no errors.
I have checked and 3.3v seems to exist everywhere it should. Any thoughts?
Thanks,
Stefan
iambehr
Feeling a little silly. 2015 toshiba drive is not fully compatible with the 2013 820-3435. No issues with the 2013 issue sandisk drive.
A school was swapping drives between students and happened to swap a 2013 and 2015 11" air ssd.
It works fine in OS however. Not a problem that needs solved then, I will put in the correct part.
Status
