appleonarim
Hi
Board was repaired 2 months ago ( liquid damaged a lot of place, ultrasonic cleaned and reballed SMC every thing was ok) but computer came back with fan noise and too slow. ASD report an error like bottom,
SMC: 0x0 (test #1) - SMC Critical Sensor Check Test
- Checks if the SMC reports any errors on critical sensors.
[16:06:36] ERROR -- 1 [The SMC reports an error on one or more critical sensors.] -- TEST FAILED
Temperature (Th1H) -- Fin Stack (test #1) - Sensor Reads Within Operating Range
- Check to ensure that sensor reads within operating range.
[16:06:54] ERROR -- 1 [Unable to read sensor] -- TEST FAILED
Temperature (Th1H) -- Fin Stack (test #11) - Extended Sensor Flat Line Test
- Checks that the Sensor changes value i.e. not stuck, with longer time allowance for change (5 mins).
[16:07:34] ERROR - -13005 [The SMC can not read this sensor] -- TEST FAILED
Replaced SMC nothing changed.
Any idea for start to check?
