[SOLVED]820-3437-B Sound Issue - No Output Devices Found
Status
Not open for further replies.
veejay
No water damage, the audio jacks looks OK. Customer says it used to work with a PRAM reset but now it doesn't.
Although the chime is present when turn on, most times in System preferences it says that No Output Devices found. If it works, when youtube for example is playing something the sound dies and the volume bar is gone when pressing the buttons and the Mac becomes laggy.
In Diagnostics it gave me once : There may be an issue with the audio hardware. Reference code : VFF001
veejay
No, I've changed the IO board and the flat cable (got a good deal on eBay for both) and everything seems to be OK. You can mark this as SOLVED. Thanks!
Status
