[SOLVED] 820-3437 Liquid Damage
Status
Not open for further replies.
arnonabuurs
Hi, I have a Macbook Air 13 inch 820-3437 with some small liquid spil around Q8150. I have replaced this chip and fixed a trace to R8156 that was gone. The fan makes a tiny move but system doesnt boot. U6100 and U1950 have power and look clean but pin 5 is pulsing and no are other lines. After measuring all voltages I get following:
820-3437
PPBUS_G3H = 8.6
PP3V42_G3H = 3.44
PP5V_S5 = 5v
PP5V_S4 = pulsing 0-5v
PP3v3_S5 = 3.34
PP3v3_S4 = 3.34 pulsingPPVCC_S0_CPU = pulsingALL_SYS_PWRGD = pulsing
PM_S0_PGOOD on U1950 = pulsing
What should i be looking for?
smiba
Might be wrong but have you checked the bios resistors? Also check for continuity
G.Beard
Have you checked for shorts on other rails and the 6259 Isense resistors are in value?
Tried burning your lip on the board?
You got a short somewhere probably.
arnonabuurs
Hi Guys, thanks for all the replies was busy with some other boards, but now back onto this one. Yes, CPU VCore is pulsing from 0 - 1.8 and back to 0.
arnonabuurs
I found a tiny liquid spil on R1380 and R1500 near Y1915 and after replacing this I got a spinning fan:), thanks for the help and this ticket can close.
Status
