[SOLVED]820-3437 - No backlight.
gcain
Take a look at how the top layer is bubbling.
Is this worth repairing?
Issue seems to be that BLK_PWM is at 0.460v and BLK_EN is also at 0.460v.
gcain
BKL_PWM @ C7704 with no screen cycles from 0.340 - 1v - 1.4v and back again.
Connect a screen and I get basically 0v.
I removed C7704 because it looked yuck with no change.
BKL_PWM should be around 3.4v right?
If I jump C7704::1 to 3.4v I get a backlight; so I'm onto it, just need to resolve BKL_PWM.
PWM can be in the 1.4-3V range. What have you done to fix? I would wipe the whole area, check traces and start fresh.
gcain
I can tell the traces are corroded out just by looking. How do I run a jumper to PWM when it comes out of CPU?
gcain
You can mark this solved.
I ran a very short jumper wire to what was left of the test point next to R7704 and backlight with brightness works again.
