[SOLVED]820-3462 Working Fine. No Webcam
Status
Not open for further replies.
bjf
This board had some minor water damage by the lid sensor causing the computer to randomly sleep. That's repaired. The only issue with it now is that the webcam is not recognized. I installed a known-good board and the webcam itself works fine. Here are my diode measurements for the connector (with webcam attached) for the bad board. 1 0
2 .470
3 .470
4 .455
5 .571
6 .502
The webcam connections seem low but there doesn't seem to be much in the circuit besides U1800. L3507 has continuity through it on both sides. I replaced the connector on the board. I'm stuck with this. Any ideas for this would be appreciated.
Yes, sorry, should have mentioned that. 5V is present at pin 4. I've also measured continuity from the connector pins to the actual webcam on a test screen that has the glass off.
2 and 3 are both are at .490 with the camera disconnected.
I have no idea. Are 2 and 3 shorted together maybe? There is nothing to this thing, 5V, GND and 2 data lines. It could be that this pair of USB data lines is fucked, but .490 seems ok.
Get a camera cable from a scrap LCD and see if all the pins have continuity to the actual camera module.
I assume you did a PRAM reset and tried booting from a USB device to rule out software.
There is your problem! Could be the connector, L3507 or crap under U1800. The last suspect would be dead U1800, but I think it is corrosion.
Status
