[SOLVED]820-3536 Power button not working
Status
Not open for further replies.
Fizzl92
This 820-3536 was waterdamaged. The board itself had no water on it. I replaced the keyboard (after shorting R5115 it turned on) and cleaned the board to be sure i did not miss any water. Now it works except the power button. The button turns the machine just some rare times on but mostly it has no function... SMC_ONOFF_L jumps from 3.42V to 3.25V when i press the power button. I am not sure whats the issue except its the SMC again...
smiba
Check the resistor from the keyboard to this line
Possibly just a bad keyboard though
Fizzl92
I tried another keyboard and still the same. If i short the pads of R5116 it works fine. R4810 is 0.887K Ohm. I also checked the Trackpad, cable and connector. All looks fine there and with the Trackpad unplugged its still the same issue.
Voltage on R4810 pin 2 when power button pressed. If it does not go down it is either a bad keyboard or connector.
Fizzl92
No Title
Voltage on Pin 5 of J4813 goes down from 3.42V to 3.22V if i press the Button. If i hold it it stays at 3.22V. I also tried another new keyboard and still the same. Connector looks fine to me
Then there is either a very strong pull up on there or both keyboards are fucked. Measure resistance from pin 5 to 3V42 to determine the pull up resistor value.
Status
