[SOLVED]820-3787 unstable S5 enables
Status
Not open for further replies.
I have no idea what you are trying to do
Yeah, that would be a fair comment.
you check PP3V3SUS_EN comes high? If yes it should pull the gate of Q8020 to pretty much 0V.
PP3V3SUS_EN only shows up if Q8002 is removed. When Q8002 is on the board the voltage at Q8002 gate changes by a couple hunded millivolts and Q8020 gate goes high low high low.
Uhm, there is a short to GND on L7520? That is at least one problem to fix first. Inject some voltage and see what heats up.
Wow, what a prize fucking moron I am... Ahh jeez. Yes, clearly short to ground but I spent ages searching for the problem going through the schematic around in circles and you say, test S0 rails, check for a short, throw in some watts and see what burns your fingers.... And it's fixed! :) Thanks for sticking with me.
It was a cap USB switch.
Status
