Hi, iv got a MacBook Air 11" (Mid 2011) 820-3024 which will run fine on the charger, (it auto powers on when plugged in), but when the charger is unplugged it turns off. No green light is shown on the charger.
When the mac came to me it looked like it had sustained water damage to the dc in board as some of the components were corroded, but the motherboard itself looks fine.
Iv tried 2x different chargers and 2x different dc in boards and it still wont charge. The battery has been changed and when it had charge in it the mac would run fine off the battery alone, until it went flat, then wont charge again, the mac reports the battery percentage correctly.
I have replaced ISL6259 also and still have the same problem.
The board has had some water damage at one point, but this seems to be only on the dc in board, the rest of the motherboard appears to be fine.
Here are some voltages from around ISL6250 :
CHGR_CSI_P
14.50v
CHGR_CSI_N
14.45v
CHGR_BOOT
12.89v
CHGR_UGATE
10.95
PP5V1_CHGR_VDDP
5.05v
CHGR_CSO_N
8.36v
CHGR_CSO_P
8.36v
SMC_BC_ACOK
2.97v
CHGR_RST_L
3.3v
CHGR_VNEG_R
1.3v
CHGR_VCOMP_R
1.3v
CHGR_DCIN
14.2v
CHGR_ACIN
3.74v
CHGR_ICOMP
1.54v
CHGR_CELL
0v
CHGR_VCOMP
1.52v
CHGR_VCOMP_R
1.44v
PP3V42_G3H
3.39v
Resistors tested :
Voltage @ R7005 = 14.1v & 14.35v
Voltage @ R7080 = 14.69v & 5.57v
Voltage @ R7001 = 5.1v & 5.05v
Voltage @ R7085 = 14.62v & 5.7v
Voltage @ R5420 = 0.061v & 0.061v
Voltage @ R7020 = 14.65v
Voltage @ R7021 = 14.60v
Voltage @ R7022 = 14.60v
Voltage @ R7050 = 8.36v
Voltage @ L6995 = 8.36v (=PPBUS_G3H)
EDIT >>>>>
So iv just tested R5311 and also R5312 and im getting 85k and 88k . Im testing in circuit so im not sure if im getting some measurement problem, or if you think these two could be the problem ?,
also R5313 is 25.30k instead of 27.4k , R5314 is correct rating.
@ Q5410 - CHGR_ACOK = 2.83v
DCINVSENS_EN_L = 0v
DCIN_S5_VSENSE = 14.59v
PPDCIN_S5_VSENSE = 14.62v
PDCINVSENS_EN_L_DIV = 7.18
DCINVSENS_EN_L = 0v
CHGR_CSI_P
14.50v
CHGR_CSI_N
14.45v
CHGR_BOOT
12.89v
CHGR_UGATE
10.95
PP5V1_CHGR_VDDP
5.05v
CHGR_CSO_N
8.36v
CHGR_CSO_P
8.36v
SMC_BC_ACOK
2.97v
CHGR_RST_L
3.3v
CHGR_VNEG_R
1.3v
CHGR_VCOMP_R
1.3v
CHGR_DCIN
14.2v
CHGR_ACIN
3.74v
CHGR_ICOMP
1.54v
CHGR_CELL
0v
CHGR_VCOMP
1.52v
CHGR_VCOMP_R
1.44v
PP3V42_G3H
3.39v
Resistors tested :
EDIT >>>>>
DCINVSENS_EN_L = 0v
DCINVSENS_EN_L = 0v
