[SOLVED]Noise in video 820-2936
Status
Not open for further replies.
MDY
Liquid board arround lvds. I replaced lvds connector and reflowd some areas. LVDS and screen was also damaged so I replaced LCD cable and screen too.
Now I have video but there is noise like in the image. When boot to OS X is worst (red noise). I checked lvds again and it is solder well. Any thing that I can check?
I compared with working board and I found only different in pin 34 - LED_RETURN_1
WORKING BOARD - 534
FAULTY BOARD - 1
I checked R9717 and it is 0 ohm
LED return has nothing to do with LVDS. Bad connector soldering or bad cable.
There is also no pin 34 on a 2936 board, it's a 30 pin connector. I assume it is 24 and it seems shorted to GND, likely due to bad soldering on connector too.
Status
