[SOLVED]QFN broken pad
Status
Not open for further replies.
Nick
Hello everyone, i have a motherboard (not apple) to fix, i need to change a QFN package IC but it was so burned that it took a trace with it, how can i fix this situation and/or solder a jumper wire to that qfn in order to restore the trace? thank you guys
Solder the IC and use a small wire from the pin on the IC to the trace..... You can use magnet wire or pre-tinned wire, lately I'm using the wire inside USB cable from phones, it is pre-tinned.....
but this IC has pads ONLY under it, there isn't the classic tiny "bend" on the side like Mac's ISLs. i am gonna try to solder a wire under it and then solder the ic in place hoping the wire doesn't move too much. Also nice tip for the wire! thank you
There is also enough "pad" on the side of the chip to solder a wire to, does not even need to go under it really.
I am a lazy cheap fuck and I ended up fixing the donor board instead of the original one. I Still bought a brand new chip and I am gonna try to solder it on the weekend for "fun" and training
Status
