Ultrasonic settings?
gadgetfix
Hey all. Just wondering whats the safe temp for ultrasonic cleaning? I usually do 1 minute on each side? 60 degrees celcius?
gadgetfix
excellent thanks for the input.
and also anyone else running crest what power>? max is always best? 9?
thanks heaps
gadgetfix
another thing im curious to know is, does anyone dry their boards? to prevent liquid remaining under ic's bga's or whatever?
would putting them in oven @ low temps like 50c for 10 mins help as i really cbf waiting overnight.
JohnB8812
I think I normally used the crest on 5 at my old job and it worked well. Normally I ultrasonic it, then put it in alcohol bath for a minute or 2 and then air dry it with paper towel for about a minute. Optimally, an oven would be good but I would use a heat gun on low to dry alcohol quickly then used canned air to blow out alcohol under BGA chips and never had an issue with it firing up after that
Air dry for a minute???? No way liquid underneath BGA chips will be gone.
Just put it in an oven at 120C for 10 minutes.
