thread top ad
Collapse
Announcement
Collapse
See more
See less
[SOLVED]820-2915-a no power, no green light
Collapse
This topic is closed.
X
X
  • Filter
  • Time
  • Show
Clear All
new posts
  • andrew boren
    replied
    awesome well next time ill have an idea how to test that little package. thank you, can i get you to close this thread please and thank you for all your help
    Leave a comment:
  • dukefawks
    replied
    Not really, you can remover the gate resistors and then test if both FETs open and close. Check on youtube how to test a FET. The gate needs to be disconnected from everything to do that.
    Leave a comment:
  • andrew boren
    replied
    7080 was the problem, i had a feeling it was, is there now way to test that part?
    Leave a comment:
  • dukefawks
    replied
    That means U7000 should be ok. Change Q7080 and check the gate voltages and resistors to U7000.
    Leave a comment:
  • andrew boren
    replied
    ok got the fake charger, ppbus_h3h is 12.56. what else should i check?
    R7005/21/22 all have power, r7005 is 18.5, r7021 is 19.03 and r7022 is 19.03
    Leave a comment:
  • dukefawks
    replied
    When you put 18.5V in the system the 3V42 bus should at least come high.
    Leave a comment:
  • andrew boren
    replied
    ok so even putting in 18.5v in on pin 2 of f6905 and plugging in the 85w apple charger, did not give a green light. i do have a fake charger on its way, praying its fake, spending less than 20$ on it and it has no apple logo. lol, is their any more testing i can do before the new charger arrives?
    Leave a comment:
  • larossmann
    replied
    Remove F6905. Place 18.5v from a real bench power supply on pin 2 of F6905. Then plug known good 85w charger in with known good dc in board. If it works, Q7080 is bad.
    If you do as duke says and get a knockoff charger this will be easier to troubleshoot.
    Leave a comment:
  • dukefawks
    replied
    Last time, get a fake charger for trouble shooting. Then we can go further with this.
    Leave a comment:
  • andrew boren
    replied
    the mac works with a third party charger, at least it did, if i had a short wouldnt it never have worked? it i remove the fuses 7040 and 7041 i shouldnt get any power since PPBUS_G3H would be disconnected to the system.
    Leave a comment:
  • dukefawks
    replied
    Short on PPDCIN, 3V42? Also remove F7040/41 without U7000 you risk getting the full adapter voltage on PPBUS!!
    Leave a comment:
  • andrew boren
    replied
    with or without u7000 i get no 3v42 power , green light for one second then it goes off, and wont come back on unless i leave it unpluged for a few min
    Leave a comment:
  • dukefawks
    replied
    ACOK is not being pulled low by U7000. Is 3V42 present now?
    Leave a comment:
  • andrew boren
    replied
    if u7000 is removed what makes the green light still come on? my problem lies there
    Leave a comment:
  • dukefawks
    replied
    Uhm, take the board with the bad GPU to Apple for a free repair.....
    Get a fake charger for trouble shooting.
    Leave a comment:
thread bottom ad
Collapse
Working...
X
