820--3332 board power not working with battery!!!
turbo
good known battery, good known tested keyboard, U8900 re soldered, working good,
board had slight liquid damage , cleaned now , when power connected computer turned on all good, , with battery only, power button does not work,
SMC_ONOFF_L goes low when i press power button, any idea what could be wrong?
after turns if disconnect power it works all good with battery, ONLY PROBLEM IT WONT TURN ON WITH BATTERY ONLY
So battery is recognized under OSX and even charging?
Please reply correctly to the questions.
Also, do NOT quote an entire post, visible few centimeters above; maintain forum aesthetic.
turbo
yes battery recognised charge and everything i can see under osx, when macbook turns on i can remove charger it will work with battery, also i tried with known good battery same result.... both battery charge and work, i can see under osx .
Please reply with new thread, insted of a comment.
Is more easy to follow the thread.
Check if PM_PWRBTN_L reacts (drop pulse) when trigger SMC_ONOFF_L signal; use R5015/16 pads, instead of power button.
To test on battery only (no charger), of course.
turbo
battery only test result, using R5015/16 pad does NOT work , also PM_PWRBTN_L goes down when triggered
SMC_ONOFF_L signal
turbo
also i notice if i turn on mac then disconnect power and run with batter ,,, then i press power button for .001 sec it shuts off , when it run battery it shuts off right way as soon as i press power button
