thread top ad
Collapse
Announcement
Collapse
See more
See less
820-3208-a
Collapse
X
  • Filter
  • Time
  • Show
Clear All
new posts
  • 820-3208-a
    R6905 keeps blowing up before diode D6905 and reaching pp3v42.
    Any idea why?
    Its been trolling me for some time now.
  • #2
    "reaching pp3v42"
    Who?
    I don't really understand what you mean...
    Check all 4.7uF (C6990-97) placed after D6905 and U6990.
    Now D6905 is probably shorted too.
    Comment
    • #3
      C6991 is shorted to ground. I detached the CAP. the short is still there inside the board it seems under the pad... How do I go about to solve that issue? drill a hole in the board through it?
      (pp3v42.. forget that, i was just mumbling.)
      Comment
      • #4
        Dig a bit in the board, until short is gone.
        You can also try to cut off the trace and bypass "on air" that point, if needed.
        Comment
        • #5
          hi 2informaticos, sorry late reply, was busy with my other businesses..
          I dig the bottom, there is no continuity now.. But the resistor 10 ohm, still exploded after putting a new one... So strange. what could cause that to happen.. ? The trace is inside the board to the other side.. wont be possible to cut off the trace, unless u have a great idea how to?
          I could add jumpers from that cap to the other points its should connect to and see what happens. What do u suggest?
          Comment
          • #6
            You can discard one cap.
            Be sure to have continuity for all others and no short, or low value to ground.
            Comment
            thread bottom ad
            Collapse
            Working...
            X
