Macbook A1466 820-00165 U4500 Heating Up
Instafixx
Machine had come in for SMC Issue. PPBUS was 8.17V.
Reballed the SMC and it started working. Came in again after 1 week. It has intermittent shut down issue. As if the machine gets hot and it goes off - fan goes high.
Thermal scanning shows U4500 getting got .
How to do go about it
Instafixx
Chip removed. Machine turns on and works. But shuts down randomly.
I plug it on charge. I get chime. it turns on and then shuts down. This will happen many times and then it will turn on randomly.
Instafixx
It is very random. Sometimes for 15-20 mins.
Sometimes in 1-2 minutes. But its mostly 1-2 minutess. Very rarely it stays up till 15-20 mins.
In SMC bypass shuts down fast too?
If possible, check the sensors with HWMonitor.
Just in case, try to run diagnostic mode.
Instafixx
Tried. It shut down during diagnostics. U2800 heating up - but very slightly. Have removed that too. Will check it for a day and let you know.
