Macbook 820-3437 Not Turning ON
Instafixx
Drawing only 28 Amps.
PPBUS is 8.6V
PP3v43 is 3.4V
U1900 was mildly heating up.
Replaced it. Still the same.
PP3v3_s5 is 0.065 Diode to ground
RTC Pull up resistors line are shorted .
BAD U1900?
You can't heat anything injecting voltage there.
However, a good thermal camera can show you very small temperature differences.
Injecting until 4V into 3V3_S5 shouldn't cause any damage.
Remove CPU heatsink first.
"PP3v3_s5 is 0.065 Diode to ground"
Normal reading after U1900 was replaced?
"PPVRTC_G3H is shorted"
If pure short, start injecting with 1V.
