[help] 820-00928 stuck at 5v rebooting!
phantom
Hi to all ! I have to fix this 820-00928! I have a lot of corrosion like you can see in the picture
I have reballed the controller, replaced 3 resistor and in the video you can see the behaviour…all ports at 5v 3 ports rebooting, one port (the on corresponding to the controller that I’ve reballed) not rebooting. Could you Help me? Thanks
VIDEO
So your problem is on U7000 area.
Check R/C/Q7030/40 and their traces.
Also check resistance (ohm scale) over C7020/3.
If all good, replace U7000.
