NAND internal failure is known for sudden death symptom.
However we can't rule out all power rails.
Not exact documentation available about how to follow power on sequence.
All related data comes from 3rd part tehnicians; based on their repair experience.
I installed the original NANDs again, and the power cycling stopped. I have no clue why or how.
I managed to successfully DFU restore the device, and macOS installed successfully.
Any idea what the issue was? There was no corrosion or damage under the NANDs.
Edit: As soon I click on a language the MacBook reboots.
