MacBook Pro A1708 820-00840 - 20v, 0.5a, Fan Spinning
gap-ruse-pried
I have a MacBook Pro A1708 non touchbar that wont boot. Getting 20v, but only 0.5a when ssd is disconnected, around .65a when ssd is connected.
Upon plugging in usb c power, the fan spins for 30 seconds then stop. It’ll go again after a little while, but stop again. Like it’s trying to start but can’t.
Tried caps lock and got no light. I do have a usb c to regular usb adapter, so I plugged in a couple flash drives. One of them was blinking rapidly and consistently, the other didn’t blink at all. When I plugged them into my regular pc, they both light up and flashed normally.
Also tried a usb c to hdmi adapter in case it was just a display issue, but I didn’t get an image on the monitor.
I’ve tested some components as noted below:
PPBUS_G3H (F7000) ~13.08 V
PP3V3_G3H (C7080) ~3.42 V
PP5V_S5 ~5.12 V
PP3V3_SSD ~3.32 V
PP1V8_S0 ~1.8 V
PPVCCCPU_S0G ~0.95 V
PPVCCSA_S0G ~1.04 V
L7410, L7420, L730 0 V
SMC_RESET_L ~3.42 V
SMC_BC_ACOK ~3.42 V
PM_RSMRST_L ~3.3 V
PMIC_RSMRST_L ~3.3 V
PM_SLP_S4_L ~3.42 V
PLT_RST_L ~3.32 V
Not sure where to go next? I have experience with microsoldering but mostly on consoles. This is my first time doing any sort of Mac repair, so any guidance is appreciated!
Monitor CPU core voltage.
It should drop to 0.65V aprox, after 10-15s; when board really boots.
BTW, it is available at L7210/20 for test.
Do you have known good battery, holding some charge?
gap-ruse-pried
Hi, thanks for your reply. I forgot to mention, the battery is toast so it is not hooked up, just running straight from the power adapter.
I measured both L7210/20 and both sides on each are around 0.955v
Any fault history available?
Both coils are tied together; enough to check one.
BTW, DC voltage must be test on output pin of the coil (only).
Input pin should have similar value, but that is not a real DC voltage; an osciloscope can show you the reason.
0.95V on VCORE means that board doesn't boot, is stuck.
Just in case, monitor its behavior from start until 30-40s.
You can try flashing known good BIOS (U6100).
Please, write directly into bottom reply box, instead of clicking Reply button.
I don't see any reason to quote an entire post, visible few centimeters above.
gap-ruse-pried
No fault history as far as my friend knows, the only thing he mentioned was he took it to Africa and after charging it there, the next time he tried to turn it on it wouldn't boot and it got very hot. Not sure how helpful or relevant that is though.
It's still 0.95V after 30-40s, even after the fan stops spinning.
Will try flashing BIOS. As I am inexperienced with Macs, is there any downside to flashing, or anything else I should try first?
gap-ruse-pried
Thank you. Since I've never done this and have been googling, it looks like I have a couple options. Buy a Medusa 3, which is expensive but easier to use, or buy something like a CH341 but it would be more difficult since I would have to remove U6100. Am I understanding this correctly?
Before going this route, is there anything else I should test or look for on the board that I haven't already?
CH341 is the chipest and fastest way.
Medusa takes time to arrive and you may not need it soon for other jobs.
It is a good tool if you repair MacBooks manufactured until 2017.
Since 2018, we don't have direct access to BIOS anymore.
Just in case, check if PLT_RST_L goes high.
