Macbook A2338 820-02020 5v
MrPhoneDoctor
Hi Everyone new here, I am working on the above macbook model that is not charging. It turns on with a charged battery however does not take charge. I am thinking this has something to do with current sensing.
I put under thermal camera and had chips UF400 and UF260 heat up. I replaced these 2 chips and heating is no longer present. UF260 was reprogrammed with proper bios. I am stumped, have spent few days trying to figure this out so am now reaching out to all you masters out here.
Below are some readings before fuse removal.
Ameter - 20v in 5v load & 0-150ma fluctuating power.
F5200
Voltage - 4-5v fluctuating
diode - .518
UF400
FF200 - 4-5v fluctuating
LDO - 1.5v
LDO Core - 3.3v
UF500
FF202 - 4-5v fluctuating
LDO - 1.5v
LDO CORE 3.3v
PPBUSAON - 8-12v Fluctuating
PP3V8_AON -3.8v
Removed fuse to test upstream and am now getting constant 12v on pin 1 F5200
Diode Pin 1 F5200 .566
Diode pin 2 f5200 - .510
MrPhoneDoctor
Did you replace UF400 from donor board, same model and position?
I purchsed the uf400 from my vendor phone lcd parts. Installed in correct position. Attached is photo of chip removed and the new chip installed.
With "position" I meant that it MUST be removed from same position of donor board (same model).
I wasn't talking about chip orientation, when soldering.
Please, write directly into bottom reply box, instead of clicking Reply button.
I don't see any reason to quote an entire post, visible few centimeters above.
MrPhoneDoctor
Ok so I don't know what position the chip came from. It was purchased individually from my parts vendor.
Do I need to get a Donor board with same model # 820-02020 and replace the new chip on the right that was installed?
MrPhoneDoctor
Donor board received installed cd3217 from the donor board (exact location) installed fuse and I am still getting same fluctuating amperagea as the photo above. Checked LDOs and diodes and power tested same as above as well. I am stumped any more suggestions?
