Macbook A2338 820-02773 LT400
Instafixx
Wont turn on with Trackpad connected.
Disconnecting the trackpad it will turn on fully with LCD working.
LT400 was burned.
Reconstructed it and replaced the Coil.
Now it turns on but no backlight.
Instafixx
Issue was solved but i know i am getting Sleep/wake issues and trackpad and KB not working.
AMR_RIGHT_OR_ND_1V8 was 1.3V
Replaced RR300 to force the signal to 1.8V
Sensor working fine. But no KB/TP
IPD_LID_OPEN_1V8 is always high.
Instafixx
The issue is random. Currently i connected all parts except KB - it is working fine
Then i connected KB - now both are working fine. .
I have disconnected the KB and kept it. Will observe.
If and when TP stops working - what should i do?
Instafixx
When TP stopped working next morning - i replaced the TP Flex and kept it with KB disconnected.
Now its been 24 hours and TP is still working. Can we conclude that TP Flex is the problem?
