00165 low 3v42
grmacs
Board isn't necessarily clean but no liquid contact or relevant visible corrosion. PP3V42 is usually either 1.5V or 2.2V with no correlation to anything I can tell.
Board is on bench and checked with Main flex cable removed also and tried with different DCIN board.
Things I tried: replacing U7090
Pulled U7100, U1900, U5110, SMC. Thoroughly inspected areas with direct pp3V42 connection. NO change in PP3V42 with any of those components removed.
Also get 1.2V on PP1v2_VDDC_SMC_S5
Replaced L7095 also.
Checked with FLIR also... not seeing anything unusual but suspect this is not major short. I get .313 in diode mode on pp3V42
Remove C7095 and test.
Check R7095/96 integrity and traces.
Post diode mode to ground at L7095.
Play with Ra/Rb to get correct voltage.
grmacs
Voltage dropped? to 1.2V with C7095 removed but guessing that didn't cause the drop. Regardless, no pp3v42 present still.
Diode at L7095 is .313.
What do you mean Ra/Rb to get correct voltage?
