00165 ppbus stuck at 4v
Patricia
Hi to you all nice people , Merry Christmas first of all :)
Got a 820-00165 board with no liquid damage or corrosion whatsoever. Had a short on C7430 , replaced it and ppbus went up to 4v (from 0 )
now the board is taking 23 mA and i am stuck :) pp3v42 is ok and i do have green and orange light .
Measured around the U7100 and pin 1 is 0 V , that cant be ok .... so traced back to R7185 and R7186 and they are up to specs .... The voltage there is probably not ok though , on pin 1 R7185 =18.51 and pin 2 =7.51V and the R7186 pin 1 =7.51 and pin 2 = 0 V
The Q7180
pin 1 and 2 = 18.51
pin 3 = 7.51
pin 4 and 5 = 17.95
pin 6 = 17.79
if you had this board would you replace the isl or q7180 ? :)
Thanks in advance
If you get 8.58V at R7150 removing F7140, then no problems on U7100 area.
Resolder F7140 and post diode mode (both directions to ground) at PPBUS_G3H.
Patricia
Jesus do i feel stupid ..... I DID check it in the initial stage and it was still ok :) guess it said goodbye during the reparation :)
What can i say besides thank you a thousand times !!!
mark it as solved :)
