razorwoods
I had a 2010 MacBook Pro 17" come in the other day with a memory issue. Easily figured out that the bottom memory slot is intermittent and after a few minutes the machine would freeze or reboot itself or toss the dreaded 3 beeps if any memory module was in there. I did verify with several new memory modules that this was the case and not bad memory. Just using the top slot works fine with any module I tested. While some people just say "max out the single slot and call it a day" I have a little time and would like to investigate how I might go about repairing this. Also this customer wants to run 8GB's and from what I've seen you can't put a single 8GB (pc3 10600) module in the working slot without the machine giving 3 beeps. Any suggestions would be appreciated.
