2879 green light, PPBUS_G3H no PM_SLP_S4 liquid spill entry at USB ports
grmacs
Not getting any s4 or higher rails other than found some voltage near the USB's on PP5V_S3_RTUSB_B_ILIM and /_LTUSB_B_ILIM caps. Only noticeable corrosion was at U4650. Unfortunately the customer tried cleaning the board first.
grmacs
That started the board?! It actually ended up booting. I know I had tried to get the board to start with smc bypass but I hadn't triggered the onoff since reflowing the SMC.
Does this board not start upon connecting to MS1? I don't recall but am thinking that is typical for 2010 and earlier... At this point I believe everything is working except the battery which probably toasted from the spill. I'll run it through testing and report back if further issues.
Thanks!
