Phiberop840
So I am fairly new to Apple Logic board repair but not Electroniscs or Soldering. Hoping that you can help me here and tel me the points to check first and what the values should be for each, If this is something already out and solved please link me,
I use an Apple USB C Cable to an Apple Charger 87W USB-C and a USB C Black Test Meter bought from you guys. I have 3 of each board and toasted one of the power boards smoked, turned bright orange then black and never worked since. Not sure what happened, So 3 boards that are like new and same with the rest of the machine. As stated, I have 3 boards and 2 good Power boards, and I get the same on all 3 boards when I check for fan spin using 2 power boards on the 3, The one is dead now. What other rails should I tackle as well is there a quick list to start off with? I will post as soon asa I ksff
Thank you,
M
Thank you,
M
