3437 no wifi
board has no liquid damage. i have changed out wifi card with known good and the board does not detect the wifi.
pp3v3 - 3.3v
pp3v3_s4 - 3.3v
AP_reset_conn_l - 3.3v
Check C3530/31 and be sure to get 100MHz clock at J3501.
Clean J3501 contacts and check diode mode to ground at data lines.
Bluetooth works?
Do PRAM reset and try known good USB macOS.
You can also try to flash BIOS, just in case.
If you access recovery menu, wifi still not available?
