3476 external display works, NO image, no backlight
grmacs
It's been a while since I worked on this board, but I believe I had occasional backlight with this board previously but the LDVS connector was damaged... I replaced it and I have double, triple checked solder and connector inside but this board acts like it doesn't see the display. I also tried another compatible display with working backlight/image and same.
0V on PPVOUT S0 LCDbklt and over 1V diode red to ground WITH display connected
0V on PP5VR3v3_SW_LCD
"0V on PP5VR3v3_SW_LCD"
Do you get this voltage at least in the first few seconds (at chime)?
It must appear even if no LCD connected; will go off soon in such case.
Check EDP_PANEL_PWR and LCD_PSR_EN in these first few seconds.
At least one needs to be high, in order to enable U8300.
