82-000165 no I/O usb
Kyle93
Have a 820-000165 that wont recognize the usb port on the I/O board. I have tried a known a couple good I/O boards and cables. Pins on the board look perfect with no corrosion.
What to check first??
Check LIO connector from MLB.
Also check diode mode on data lines (PCH side).
Be sure resistors, capacitors and TVS diodes are all OK.
