hi there
820-00045
no visible water damaged, unknow history
does look like been worked before on some areas.
the little blue led right to the battery connector is glowing
but no image or chime,
PP5V_S0 is missing, also obviously. no cpu vcore...
ppbus_g3h is 8.6v
PPVIN_G3H_P3V3G3H is 14.80v
PPVBUS_E85 is 14.77v instead of 20v (?)
PP3V3R3V0_AON is present
PP5V_S0 is missing
sometimes it goes to 4.8-9v for a second and than goes away
the board looks like has been tried to repaired before
some remaining of flux on it on those areas -
the u4700, the known common issue with theese looks like been replaced
also u4600 area has some flux on it and looks like been worked on
the area where u7860 and u7865 look like been worked not so pretty work been done there
i was thinking of replacing u7860 and u7865 as a start as they look very bad,those has to do with the 5v s0 rail?
any other advice on what to check for putting back PP5V_S0?
820-00045
ppbus_g3h is 8.6v
PP5V_S0 is missing
