820-00138-05, no backlight
First, remove the ground wire from BKLT_SD.
Post BKLT_SCL/SDA voltage and diode mode to ground.
Did you try another compatible LCD assembly?
PRAM reset had what looked like a small flash on the screen right after the first or second reset, but nothing afterwards.
LCD_BKLT_PWM_R - 3.2v
Got it working :) resoldered L7710 and Q7701, we have backlight.
Unfortunately, after a while of the board being turned on and functioning totally normally, the system hung for a moment and fans went up, and now the fans blare shortly after turning the computer on--classic PFM006, NDC001, PPN001. It's probably the I/O board cable as I saw it had some corrosion on one end--will replace and update with if it fixed.
New update: not sure if this is related or just a quirk of the issue, but the computer runs fine with only one fan installed. No slowdowns, no fan blurs, nothing. With both fans plugged in, however, the computer quickly picks up their speed and runs very slowly.
edit - now it's slow with one fan plugged in again. Confused as to why it's working differently some times rather than others.
Does this indicate anything specifically? From what lines I see that are associated, none are shorted--though I didn't test their voltages yet. Will give a more detailed update when flatcable comes in.
